Parameter Sweep Undoes Geometry
Posted 19 apr 2021, 14:27 GMT-4 Low-Frequency Electromagnetics, RF & Microwave Engineering Version 5.4 1 Reply
The below post is related to an archived discussion
I created a geomtry then simulated a few times using EM wave solver in the frequency sweep and the parametric sweep. Then I saved a new version of the file and made an edit to the geometry (added a filet on some edges). I tried to run the parametric sweep again and I get the error that the filet applies to no edges, which it certainly does. In fact, the parametric sweep is undoing my geometry. The variables I am sweeping should not affect the filet in question.
Apparently someone has had this issue before with a parametric sweep undoing geometry. Has anyone else encountered this bug?
