Need help with Magnetic and Electric Fields Error
Greetings,
I'm trying to generate a model with a cylindrical anode, two metallic electrodes, and two magnets with the MER Module so I can model both the E and B Fields together so I can look at ExB drift effects. However, I keep getting this same error:
Failed to find a solution.
Singular matrix.
There are 213295 void equations (empty rows in matrix) for the variable mod1.V.
at coordinates: (-0.308496,-0.261123,-0.294355), (-0.299595,-0.278459,-0.287582), (-0.289647,-0.29545,-0.280739), (-0.288168,-0.272107,-0.304823), (-0.278712,-0.28882,-0.298166), ...
and similarly for the degrees of freedom (empty columns in matrix).
I've double-checked all of my material properties and I've input the electric potentials using the Initial Values, but it's still having a hard time looking for the voltage (?). I'm not sure what boundary conditions I've missed to get a singular matrix and nothing's popping out at me. Does anyone have any ideas?
Live Long and Prosper,
JAY
P.S.: I can't attach my file because the size of the file is too large.
3 Replies Last Post 18 mag 2012, 16:41 GMT-4
Posted: 1 decade ago 18 mag 2012, 14:42 GMT-4
Hmm. Not sure, based on the limited info. There may be a clue in your statement that you "input the electric potentials using the Initial Values." I haven't used the AC/DC module much lately, but "initial values" doesn't sound like the right place to specify electric potentials. Potentials would normally be specified as boundary conditions, not initial values, for most problems.
Posted: 1 decade ago 18 mag 2012, 15:47 GMT-4
If it's i MEF are you sure all your materials have some conductance ?
0[S/m] is not allowed, use 1 or 10 for air, even if it is not really "true"
Hi If it's i MEF are you sure all your materials have some conductance ? 0[S/m] is not allowed, use 1 or 10 for air, even if it is not really "true" -- Good luck Ivar
Posted: 1 decade ago 18 mag 2012, 16:41 GMT-4
Ivar,
Thanks for the advice. My solution is converging now and I'm getting results that are comparable with my B-Field only model. Thank you!
JAY
Ivar, Thanks for the advice. My solution is converging now and I'm getting results that are comparable with my B-Field only model. Thank you! Live Long and Prosper, JAY
