Solution of Steady-state as an initial value to solve time dependent problem
Hi folks,
I have a model where I need to first solve it for a steady-state and then use the solution as an initial value for the time dependent case. I read the COMSOL manual but did not find much help. I also read a few postings and comments on the discussion forum, but not too many details. Does anyone know how is it done from Solve menu in COMSOL GUI? Any example from model library would be fine.
Thanks and best wishes.
Sandra
2 Replies Last Post 29 gen 2010, 03:41 GMT-5
Posted: 2 decades ago 29 gen 2010, 02:11 GMT-5
Hi Sandra
It's the settings of the "Solver Manager" window and sub-tabs you should study (try an indexed search on your help files info and examples, as usual, are rather scattered around indeed).
Basically, run your first model (by deciding for which sub-enetity to "Solve For" and to "Output", if required (see relevant tabs), you store the solution (you might then save this as a first step in the "Sequence" tab), then you select in the "Initial Value" tab: "Stored Solution" (or "current solution" if you restart, by the way "restart" means from current solution, but pls check/try it out ,sometimes I get it wrong ;), finally you select, if relevant "Solve For" and "Output" items, and you run the second/third ... run (then you might save this is the "sequence tab, so that this is done automatically in this way for the next "global solve")
Hope this helps
Hi Sandra It's the settings of the "Solver Manager" window and sub-tabs you should study (try an indexed search on your help files info and examples, as usual, are rather scattered around indeed). Basically, run your first model (by deciding for which sub-enetity to "Solve For" and to "Output", if required (see relevant tabs), you store the solution (you might then save this as a first step in the "Sequence" tab), then you select in the "Initial Value" tab: "Stored Solution" (or "current solution" if you restart, by the way "restart" means from current solution, but pls check/try it out ,sometimes I get it wrong ;), finally you select, if relevant "Solve For" and "Output" items, and you run the second/third ... run (then you might save this is the "sequence tab, so that this is done automatically in this way for the next "global solve") Hope this helps Good luck Ivar
Posted: 2 decades ago 29 gen 2010, 03:41 GMT-5
Hi Ivar,
Thanks a lot for your input. I could see it working well.
Sandra
Hi Ivar, Thanks a lot for your input. I could see it working well. Thanks, Sandra
