Internal boundary conditions for diffusion equation
Posted 23 giu 2009, 13:20 GMT-4 Chemical Reaction Engineering Version 4.3a, Version 4.3b 10 Replies
I'm modeling simple diffusion in a 2D geometry; however, the geometry contains some internal boundaries that I would, at times, like to be able to represent as walls. Consequently, I need to specify a zero flux across these internal boundaries. While it is easy to specify a flux discontinuity, specifying a zero flux on both sides of the internal boundary is not obvious.
I suspect there is a simple answer, but I have yet to be successful in finding it.
cheers,
-joe
I think the best way to do this is to turn off 'active in this domain' for the adjacent subdomain. This will make the internal boundary effectively become an external boundary. If you need to model diffusion on the other side of the wall, you can add another diffusion equation system for that subdomain. Hope this helps.
Adam
That's a good idea, but unfortunately, the internal boundaries do not subdivide the domain, so there is only one domain. I can solve the problem by making the internal boundary an external one (give it some width), but then I have two different geometries and two different model files, which is what I'm currently doing.
The overall goal is to be able to easily turn internal baffle walls on and off so that I can easily examine their effect.
cheers,
-joe
I'd suggest the idea shown in the model linked to at the bottom of this entry. The concept is pretty general, so I will outline it here.
Some boundary conditions are available only on exterior boundaries. This is because on interior boundaries, they would cause a discontinuous solution, which is not allowed. Insulation is one such boundary condition. My model shows how to use an assembly in order to enable all boundary conditions everywhere.
Step one is to create the geometry such that it consists of one object on one side of the boundaries where you want to apply your condition, and another object on the other side. Although hidden when you first open the model, there is a line connecting the two insulating walls. This is what makes the division into two geometry objects possible.
With the use of an assembly, the walls will automatically consist of two exterior boundaries each. This makes it possible to apply the Insulation/Symmetry boundary condition. To reconnect the solution across the boundaries between the walls, create an Identity Pair and use the (default) Pair Continuity condition.
Note that the boundaries between the walls were suppressed in postprocessing. You can see them by clicking the Show All Hidden Objects button when in boundary mode.
Linus
cds.comsol.com/mg/b4a44d998329d6.zip
Estimated size: 0.1 MB
This link expires July 3, 2009. Please make sure to download before that date.
Included files:
- Interior_Insulation.mph
-joe
please help.
please help.
these files are only awailable a short time, but the explanations of Linus are straightforward. use an assembly mode and link part of the dedoubled boundary as continuity, another part with your specific physics
I am just wondering if you could send the example zip file again. I was trying to follow your description but still cannot achieve the interior boundary conditions in COMSOL. I know it has been a long time since you uploaded the file. Sorry for this request from a COMSOL rookie.
Please, you can make the file available again below?
I I can not download.
Thank you!
Regina
While the approach that Linus described should still work, the internal boundary conditions called Thin Impermeable Barrier, which was introduced after Linus's post, is a much more direct solution. It saves you the need to form an assembly and work with pairs.
It looks like the Thin Impermeable Barrier condition was introduced at version 4.3b, see www.comsol.com/blogs/this-just-in-comsol-multiphysics-4-3b/ .
Suggested Content
- FORUM Solving non-diemsional diffusion equation with dirichlet and neumann boundary conditions
- FORUM Boundary conditions on internal boundaries
- KNOWLEDGE BASE Avoiding Negative Concentrations
- BLOG How to Model Ion-Exchange Membranes and Donnan Potentials
- FORUM Internal Boundary Conditions For Diffusion Equation?.
