COMSOL hangs on loading file on Linux
I have some models which I CAN load and work with on Windows without any issues, however they don't work on Linux.
Once I load them on Linux, the model tree is loaded, but then the UI is "locked" (as if a calculation is running, but without the button in the lower right corner to cancel the calculation). I can see that COMSOL uses one core at 100%, after a couple of minutes the UI becomes completely unresponsive
COMSOL Version is 5.6.0.401 on Ubuntu 20.04. I have not yet discovered what part of the file causes this, but it's a big acoustics model.
I don't think this happened in previous versions, but I cannot confirm as I do not have the older versions at hand.
0 Replies Last Post 29 mag 2021, 06:12 GMT-4
Hello René Ebersbacher
