Releasing a particle at arbitrary point of the inlet surface
Hi all!
I'm simulating a laminar fluid flow through a channel with structures on the bottom. When I use particle tracing module the release options are 'mesh based', 'density' and 'projected plane grid'.
I'd like to know if there is a possibility to specify a single point of release at the inlet, so something like 'a start point controlled' release.
Thank you very much for your help!
2 Replies Last Post 27 gen 2015, 04:34 GMT-5
Hello Izidor Sabotin
Posted: 1 decade ago 27 gen 2015, 01:14 GMT-5
I would like to do the same thing.
I'd like to know if there is a possibility to specify a single point of release at the inlet.
Did you find a solution?
Thank you!
Hi, I would like to do the same thing. I'd like to know if there is a possibility to specify a single point of release at the inlet. Did you find a solution? Thank you!
Posted: 1 decade ago 27 gen 2015, 04:34 GMT-5
I haven't found the solution. I think in general you have 3 options:
- mesh based,
- density based,
- projected plane grid
Try to play on with those options, or find the user manual. I think there should be one option that enables this.
Sorry I couldn't help more, hope you will successfully resolve your thig.
Best of luck,
Izidor
Hi, I haven't found the solution. I think in general you have 3 options: - mesh based, - density based, - projected plane grid Try to play on with those options, or find the user manual. I think there should be one option that enables this. Sorry I couldn't help more, hope you will successfully resolve your thig. Best of luck, Izidor
