Batch Mode Issue
Hello, I am trying to figure out how to use the Batch Mode command on my computer. I have read that you must enable the COMSOL commands by going to the advanced system settings and manually adding the "comsol bin executions" in the PATH settings. I believe I have done this step correctly, however, when I attempt to run a model with the command "comsolbatch" in the command prompt window I recieve an error stating that "comsolbatch is not recongized as an external or internal command, operable program or batch file. Why is this command not working? Is there a step I am missing when allowing the Path function?
Thank you in advance
1 Reply Last Post 16 lug 2021, 07:07 GMT-4
Posted: 4 years ago 16 lug 2021, 07:07 GMT-4
try this: comsol batch -usebatchlic -inputfile name.mph -outputfile name_out.mph
