Error-System matrix is zero
Failed to find a solution.
System matrix is zero.
Can anyone please explain me about this error?
5 Replies Last Post 9 set 2013, 05:56 GMT-4
Posted: 1 decade ago 22 giu 2012, 05:04 GMT-4
most often it is because you are missing A BC or you have not fully defined the solution. Particularly, when you have many physics, you need enough BC for ALL physics independently. else the solution is not unique.
Hi most often it is because you are missing A BC or you have not fully defined the solution. Particularly, when you have many physics, you need enough BC for ALL physics independently. else the solution is not unique. -- Good luck Ivar
Posted: 1 decade ago 2 lug 2012, 18:20 GMT-4
Thank you.
Thank you.
Posted: 1 decade ago 28 mar 2013, 22:36 GMT-4
Could you please tell me what A,B and C stand for? Thank you very much~
Posted: 1 decade ago 29 mar 2013, 03:43 GMT-4
Sorry, I was typing to quick ;)
I intended to write "...a BC (Boundary Condition) ..."
Hi Sorry, I was typing to quick ;) I intended to write "...a BC (Boundary Condition) ..." -- Good luck Ivar
Posted: 1 decade ago 9 set 2013, 05:56 GMT-4
Sir
I am doing a coiled heat exchanger problem, I have defined all the boundary conditions-viz- temperature, fluid velocity, material properties but still this error ocuurs. Tell me how can I rectify this.
Sir I am doing a coiled heat exchanger problem, I have defined all the boundary conditions-viz- temperature, fluid velocity, material properties but still this error ocuurs. Tell me how can I rectify this.
