nonlinear wave propagation
I am making 2D Lamb wave propagation in hyperelastic materials with Muraghan Third Order Elastic constants, I have a impulse function as input BCs, but when I use transient study it always can not run (the last step can not converge), however, if I select linear elastic material rather than hyperelastic, it can run anyway, is there some part I should change the settings ?
Thanks.
1 Reply Last Post 2 ott 2021, 12:53 GMT-4
Dave Greve Certified Consultant
Posted: 3 years ago 2 ott 2021, 12:53 GMT-4
A source approximating an impulse function PLUS nonlinearity is pretty much a worst case for convergence in a time-dependent solution.
You could try making the "impulse" more gradual, say a half sine wave. And try decreasing the amplitude until you get convergence. Maybe you can get a useful solution that way.
Sometimes using different solvers will help. For (linear) wave propagation problems I use BDF, strict, max order 2, min order 1.
A source approximating an impulse function PLUS nonlinearity is pretty much a worst case for convergence in a time-dependent solution. You could try making the "impulse" more gradual, say a half sine wave. And try decreasing the amplitude until you get convergence. Maybe you can get a useful solution that way. Sometimes using different solvers will help. For (linear) wave propagation problems I use BDF, strict, max order 2, min order 1.
