How to know the sign of the velocity ?
I need to know the sign of the velocity in my model , It seems that there is no option in COMSOL. I have tired different probes but all of them give you the magnitude of the velocity. I need to know when the velocity change its direction so I need to know the sign.
Best
4 Replies Last Post 2 lug 2012, 01:40 GMT-4
Posted: 1 decade ago 30 giu 2012, 10:41 GMT-4
Have you tried streamlines? Or do you want more information than that?
regards,
Hi, Have you tried streamlines? Or do you want more information than that? regards,
Posted: 1 decade ago 1 lug 2012, 13:03 GMT-4
You are probably requesting the velocity magnitude which cannot be negative. You should instead look at the components of the velocity vector.
Nagi Elabbasi
Veryst Engineering
You are probably requesting the velocity magnitude which cannot be negative. You should instead look at the components of the velocity vector. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 1 lug 2012, 18:57 GMT-4
Hi Nagi,
I have also tried the components but they are all positives.
Hi Nagi, I have also tried the components but they are all positives.
Posted: 1 decade ago 2 lug 2012, 01:40 GMT-4
well normally u,v,w are positive in the +x,y,z directions, but you should be able to pplot the gradients too, this can also give you info when the flow changes direction
Hi well normally u,v,w are positive in the +x,y,z directions, but you should be able to pplot the gradients too, this can also give you info when the flow changes direction -- Good luck Ivar
