7 lug 2012, 22:20 GMT-4
Hi Ben,
I have a similar problem, not exactly same though. I am trying to look at the effect of filling a hollow channel with liquid on its resonance frequency. However, when I try to use water as the fluid medium, the software asks me for the Young's modulus and Poison's ratio of water. I am stuck here. If you are able to find any solution to your porblem that can help me as well.
-Sankha
Hi Ben,
-Sankha
8 lug 2012, 04:15 GMT-4
structural physics uses the Lagrange representation and is best suited for solids, fluids uses mostly the Eulerian representation, so when you mix structure and fluid the FSI physics is better suited, allthough if you are "filling" a volume it could be that some level set method mixed with solid wouth fit even better
8 lug 2012, 05:30 GMT-4
Hello Ivar,
Thanks for your help. The problem with FSI physics is that the software asks for dynamic viscosity of the solid domain. On the other hand 'Fixed' boundary condition can't be defined as well.
When Solid Mechanics physics is used, COMSOL asks for Young's modulus and Poison's ratio of the liquid!
Please guide us about how to tackle these issues.
Sankha
Hello Ivar,
Sankha
