MicroCantilever damping in Comsol
Hi, I am pursuing simulating frequency domain response of a cantilever (PVDF). I have done the Eigen frequency analysis and happy with the results (close to the theoretical). Now, I wanted to perform a frequency domain response with the effect of damping. The cantilever is 40micron thick, 4mm in length and 1mm in width My questions are: 1. How to get loss factor parameters for PVDF - Is it available anywhere in the literature or would it require another set of simulations with the dimensions/properties of my cantilever to yield a frequency dependent loss factor. 2. Also, what if I have multiple such cantilevers in a single design with varying lengths. As I understand, we can only input one loss factor for one design. What happens if the actual damping is geometry dependent (which I think it will be, atleast for the transient analysis), leading to the consideration that different length cantilevers will have different damping. 3. From previous discussions, I have understood that loss factor is good enough for frequency domain analysis but will be better to have Rayleigh damping parameters for time domain analysis. How can I find/calculate Rayleigh parameters for PVDF?
1 Reply Last Post 4 gen 2022, 21:48 GMT-5
Dave Greve Certified Consultant
Posted: 3 years ago 4 gen 2022, 21:48 GMT-5
Damping parameters are less often reported in the literature (make that much less often). In addition they are likely to be fabrication-dependent.
Your options are (1) the literature or (2) your own measurements.
Damping parameters are less often reported in the literature (make that much less often). In addition they are likely to be fabrication-dependent. Your options are (1) the literature or (2) your own measurements.
