Simple Linear Thermal Expansion Theory vs Model
I'm modelling thermal expansion in a 2D beam with 10mm width (L0) and 0.1 mm height. The volume reference temperature is 25 degC and the beam is at uniform temperature of 45 degC for a dT of 20 degC. The thermal expansion coefficient is 23e-6 1/K (alpha).
From a simple 1D thermal expansion calculation: dL/L0 = alpha x dT = 23e-6 1/degC x 20 degC = 4.60e-4 also, dL = alpha x dT x L0 = 23e-6 1/degC x 20 degC x 0.01 m = 4.60e-6 m
However, in my model, I get dL/L0 = 5.75e-4 (first principle strain) and dL = 5.75e-6 m (displacement).
Can anyone please help me understand the discrepancy between the theoretical calculation and the COMSOL model? I've attached my model file.
1 Reply Last Post 3 feb 2022, 13:49 GMT-5
Posted: 3 years ago 3 feb 2022, 13:49 GMT-5
Hello Sibi,
You set up the model as plane strain. To approximate a beam, you would need to make it plane stress. When you do that, the model returns the displacement you expected.
Jeff Hiller
Hello Sibi, You set up the model as plane strain. To approximate a beam, you would need to make it plane stress. When you do that, the model returns the displacement you expected. Best regards, Jeff
