18 lug 2012, 06:10 GMT-4
for the n(T) you need to define the material index of refraction as a lookup table or interpolated function related to T[1/K] take car to check carefully the normalisation, COMSOL operates by default in Kelvin, while many index of refraction formulas are related to deg C
you can perform a first analysis for T, and use the values of the first analysis as baseline for the second, for initial conditions as well as for "variables not solved for"
18 lug 2012, 06:19 GMT-4
Great
Thanks for the info!!
Great
18 lug 2012, 08:14 GMT-4
It doesn't work... Have you got some-simple-models? they could be usefull, please.
The point is that I don't know how to create a link between n(T) and T because I have to create a new variable T (i don't know)l. Program says me that "unknown variable T", is there a specific name for temperature?
thanks
thanks
18 lug 2012, 09:30 GMT-4
indeed by default if you have no HT there is no T defined. either its a constant then you add a Parameter T =293[K] or whatever value, or its a field (ie. T(x,y,z,t ...) ) in which case its easier to run a HT simulation first that defines the variable T (dependent variable of HT) and you refer to this T
18 lug 2012, 10:41 GMT-4
Yes! thanks, the problem was not to define first the variable T! jaja
Jordi Morales-Dalmau
