Can't integrate over a cross-section!
I'd like to be able to integrate over an arbitrary cross section of my model. I'm trying to integrate the poynting vector over a hole in a cavity after doing modal analysis. I'm coupling a cavity to a piece of microstrip that sits above. I'm running into some difficulty, though. My first attempt was just just going to derived values->surface integration, and then attempting to click on the hole itself... but there's really no surface defined IN the hole, so I can't select it. So instead, I go and create a new work plane, and create a circular surface inside the hole, and figure I could integrate over this. No go... the circular surface I made disappears when I switch over to define the surface integral! As a last resort, I create a 2D slice under Data Sets of the relevant cross section, and figure I'll just integrate over that, since the power flux I'm interested in is only nonzero in the region of interest... so it works out fine. Unfortunately, when I hit integrate, it just gives NaN! Yaaargh! I tried just picking the max value over the defined 2D slice, and this works just fine... Any ideas what might be going on?
The poynting vector I have defined as real(-Ey*conj(emw.Hx) + Ex*conj(emw.Hy))... I can plut this on a 2D plot surface just fine... comsol just won't integrate over it! Also, I'd love to know why the surface defined inside the hole disappears!
2 Replies Last Post 13 dic 2012, 07:23 GMT-5
Posted: 1 decade ago 19 lug 2012, 01:37 GMT-4
I'm not sure I caught you fully, but I can confirm that I often add internal domains / boundaries only for integration purpose, or to use as "easy pick" probe entities, and this works OK. I often use this for splitting up complex domains to improve the meshing control too
Hi I'm not sure I caught you fully, but I can confirm that I often add internal domains / boundaries only for integration purpose, or to use as "easy pick" probe entities, and this works OK. I often use this for splitting up complex domains to improve the meshing control too -- Good luck Ivar
Posted: 1 decade ago 13 dic 2012, 07:23 GMT-5
I am really not expert, but shouldn't you put emw.Ey, emw.Ex.... so same as emw.Hy, emw.Hx...
That's the first thing.
Second thing, did you try to express H component from E.
If you use for example plane wave, maybe you should put equations:
variableHx = (mu0_const*emw.Ezy-emw.Eyz)/i/emw.omega and for Hy, Hz the similar....
I mean, I am really not expert, but maybe you should try this.
Especially I mentioned first about emw.Ey, emw.Ex...
Stef
[QUOTE] I'd like to be able to integrate over an arbitrary cross section of my model. I'm trying to integrate the poynting vector over a hole in a cavity after doing modal analysis. I'm coupling a cavity to a piece of microstrip that sits above. I'm running into some difficulty, though. My first attempt was just just going to derived values->surface integration, and then attempting to click on the hole itself... but there's really no surface defined IN the hole, so I can't select it. So instead, I go and create a new work plane, and create a circular surface inside the hole, and figure I could integrate over this. No go... the circular surface I made disappears when I switch over to define the surface integral! As a last resort, I create a 2D slice under Data Sets of the relevant cross section, and figure I'll just integrate over that, since the power flux I'm interested in is only nonzero in the region of interest... so it works out fine. Unfortunately, when I hit integrate, it just gives NaN! Yaaargh! I tried just picking the max value over the defined 2D slice, and this works just fine... Any ideas what might be going on? The poynting vector I have defined as real(-Ey*conj(emw.Hx) + Ex*conj(emw.Hy))... I can plut this on a 2D plot surface just fine... comsol just won't integrate over it! Also, I'd love to know why the surface defined inside the hole disappears! [/QUOTE] I am really not expert, but shouldn't you put emw.Ey, emw.Ex.... so same as emw.Hy, emw.Hx... That's the first thing. Second thing, did you try to express H component from E. If you use for example plane wave, maybe you should put equations: variableHx = (mu0_const*emw.Ezy-emw.Eyz)/i/emw.omega and for Hy, Hz the similar.... I mean, I am really not expert, but maybe you should try this. Especially I mentioned first about emw.Ey, emw.Ex... Good luck Stef
