Henrik Sönnerlind
COMSOL Employee
3 years ago
17 feb 2022, 09:51 GMT-5
The orientation vectors, (solid.ep1X, etc.) are expressed in the global directions, yes.
However, there is something strange with the question, or at least the terminology. The three principal strains have certain orientations, computed from the full strain tensor. There cannot be anything like "principal strain along the direction of the force applied", unless by some coincidence, one of the principal strains happen to be oriented in the load direction.
If you are interested in the direct (or normal) strain (as opposed to shear strain) in a certain direction, the easiest option is to select a coordinate system coinciding with the load in the Linear Elastic Material. Then the local strain tensor has the orientations you are looking for.
You can also use the Matrix Transform feature under Definitions, to perform arbitrary rotations of tensors.
Henrik Sönnerlind
COMSOL
3 years ago
17 feb 2022, 16:48 GMT-5
Henrik,
Thanks for the answer. I am intersted in the strain in a certain direction (that being the direction the force is applied). Can you give me a little more instruction on how to "select a coordinate system coinciding with the load" so the strain values I attain for the strain tensor has the orientation along that direction?
I appreciate the help.
Henrik,
3 years ago
2 mar 2022, 16:33 GMT-5
Henrik,
Any chance you could provide some information on how to use the Matrix Transform feature under Definitions? My thought would be to transform the strain matrix to the system that aligns with my force vector. However, I don't understand where in the Matrix Transform feature I input a transform matrix or some "transform rule"
Henrik,
Jeff Hiller
COMSOL Employee
3 years ago
3 mar 2022, 08:51 GMT-5
Updated:
3 years ago
3 mar 2022, 08:52 GMT-5
Hello Coleman,
To request support from COMSOL staff, please use www.comsol.com/support/ .
Jeff Hiller
Hello Coleman,
