Extrude cut
Abhijit Bhattacharyya
The below post is related to an archived discussion
[I wanted to know extrude cut for 3D geometry. I made a 3D object say block. On the top surface I define an work plane. On that work plane let us draw a closed geometry. Now I want to make an extrude cut of that geometry within that block to make material extruded out of that geometry. Now if I make extrude in reverse direction i.e. inside the block and then take difference graphics do not show that the matrial was cut out of the block. Can you kindly advise?]
1 Reply Last Post 21 feb 2022, 06:48 GMT-5
Acculution ApS Certified Consultant
Posted: 3 years ago 21 feb 2022, 06:48 GMT-5
I have attached a file for you.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
