25 lug 2012, 05:06 GMT-4
does anyone ever answer is this forum...?
25 lug 2012, 08:33 GMT-4
Hi Robin,
you have uploaded a file in 3D some days ago. I couldn't answer at that time because of my work. However I had time to look at your file nowadays.
1. To see the trajectories you should change line style to tube or line and point style to None in coloring and style in Particle trajectories window in results.
2. After that, if you still see the dots instead of lines, that means there is a problem in your numbers.
If the magnetic field you're applying is too high wrt the speed of electrons, you'll see the circular trajectories as dots. So, you need to change the magnetic field and get an appropriate magnetic field/velocity ratio.
3. Try to give sensible time intervals, not (0,0.1,1) but somethings in the order of 1e-6 (or close to it) After you see some expected results, you can play with the time interval. (I think this is not that important in 4.2a but it's important in 4.2 which is not charged particle tracing but particle tracing in ACDC interface. anyways it does not harm.)
I'm attaching your 3D file. I did some changes. You can observe what I said from the file.
Ceren
Hi Robin,
Ceren
Nagi Elabbasi
Facebook Reality Labs
25 lug 2012, 08:44 GMT-4
In addition to the steps Ceren described, also check your initial particle velocity. It was too low.
26 lug 2012, 05:09 GMT-4
ok your help file was kind of confusing. you changed the magnetic force in the particle tracing module to user-defined instead of using the field from the mef module which is really dodging the problem because i want the particle tracing to use the however complex fields resulting from my geometry.
so i changed that back to use the mef fields.
then i just adjusted the numbers a bit.
i increased the particle speed as suggested and decreased the fieldstrengh.
the result is a strange behaviour of the particles which i observed in several other attempts to create particle tracings: the force only affects the particles on the inlet surface, after that the particles fly totally linear. the magnetic field strengh only affects the angle under which the particles leave the inlet!
thx for your help have a look at the attachment
27 lug 2012, 05:55 GMT-4
i solved the problem myself. to get real trajectories and not just the linear ones one has to set the start/stop time interval in the "range" settings of the time dependent study to roughly the time the particles will neeed to fly through the geometry. then you have to set "number of values" to about 50 to get a smooth trajectory. to make it clear: if you have set number of values to 1 OR a time interval so huge that there will only be only one value "in the geometry" you will only get the linear trajectories. for example if u have a particle speed of 1e7 m/s and a time interval of 0-1 seconds and set number of values to 50 you will still get linear trajectories...
4 feb 2013, 00:38 GMT-5
Reg. your thread about :
www.comsol.com/community/forums/general/thread/30528/
Reg. the model:
www.comsol.com/community/forums/general/download/file/14757/particle%20tracing%20example%20(1).mph
I was trying to add another charge particle trace physics (cpt2), for which I duplicate the particle inlet and the magnetic field. It works fine with user defined magnetic field, but once I keep the mef/acl1 , I dont observe the influence of magnetic field over the electrons.
Is there something else we need to do to use the magnetic field generated from the geometry.
Uttam
Reg. your thread about : http://www.comsol.com/community/forums/general/thread/30528/
Reg. the model: http://www.comsol.com/community/forums/general/download/file/14757/particle%20tracing%20example%20(1).mph
Uttam
16 apr 2013, 13:13 GMT-4
Uttam~
Depending on what you are trying to do, you might try the following. Instead of adding a second CPT, and as I needed to model both sodium and chlorine ions in my model (makeshift salt water), I just used a conditional to give me associated mass, diameter, and charge for each charged particle as below.
Z = -1 + 2 * mod(cpt.pidx,2)
Z is the particle charge, -1 is for the Cl- ions (also true for an electron) and the +2*mod() says that if the particle index number is even +0, but if the number is odd +2 to make the odd particles of a +1 charge as in Na+. Let me know if that doesn't make sense. It seems to work for me, though I am having other issues with my models at the moment.
Uttam~
