Edgar J. Kaiser
Certified Consultant
3 years ago
25 mar 2022, 07:12 GMT-4
Hendrik,
in mf you cannot apply an electric potential boundary condition, so ground is not an option.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hendrik,
Cheers
Edgar
3 years ago
28 mar 2022, 08:52 GMT-4
Hi Edgar,
thank you for the reply. Alright.
I simply want to simulate a piece of conductor with 2 coils around it. I can easily define a current through the coils via the option "coil", but I also want to define a current through the piece of conductor. In the mef-package I could do it with a terminal on one side and ground on the other. Do you know how I can apply a current in the piece of conductor in the mf package?
Thank you and kind regards,
Hendrik
Hi Edgar,
Hendrik
Edgar J. Kaiser
3 years ago
28 mar 2022, 09:29 GMT-4
Hendrik,
you can use the piece of metal as a coil as well. A coil in Comsol doesn't need to look like a typical helical coil. Also it doesn't need to be a closed loop if you guide the terminal ends to an outside boundary of the model. Check the documentation about the requirements for coils.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Hendrik,
Cheers
Edgar
