Simulation analysis of temperature field
Posted 26 mar 2022, 09:01 GMT-4 Electromagnetic Heating, Heat Transfer Version 5.6 1 Reply
hi,i am a COMSOL greener The carbon nanofibers I'm working with are electrically heated, similar to incandescent lamps, where the temperature changes are transient warming-thermal Dynamic equilibrium-rapid cooling after power failure.
I USE COMSOL software to simulate a series of steady-state temperature with the applied voltage, resistance data, to fit a T (u, R) three-dimensional surface graph, but according to the equation of (u ^ 2)/R = A * t + b * t ^ 4 + C, the goodness of fit is very low, only about 0.4, the fitting effect is not good
(U^2)/R=AT+BT^4+C
On the left side of the equals sign is the joule heat production power expression
On the right side of the equals sign are the expressions for convective and radiative heat dissipation
At steady-state temperatures, there is a heat production-cooling equilibrium, so I wanted to use this formula to fit, but it didn't fit very well
Now there are two cases, one is my COMSOL model built wrong, resulting in simulation of the temperature data are all wrong, and can not be fitted
Another is the above-mentioned physical model expression error, the lack of some items, that is, the physical model is not accurate, resulting in bad fitting results
In addition, there's another pitfall here, which is this R, which is not a stable value, this R is just the resistance at room temperature, and as the temperature goes up, this R is going down, carbon-based materials have a negative temperature property, with higher temperature and lower resistance. In COMSOL, the simulation is in the form of conductivity, which is a function of temperature, which I've got
