Henrik Sönnerlind
COMSOL Employee
2 years ago
4 mag 2022, 11:10 GMT-4
A pressure condition is a Dirichlet boundary condition for pressure acoustics. This means that the pressure eigenmode will always be zero where the pressure is prescribed (to any value).
Henrik Sönnerlind
COMSOL
2 years ago
8 mag 2022, 22:47 GMT-4
Hi Henrik,
Thank you very much.
I also want to know what is the difference between constraints and boundary conditions in acoustics, I know that constraints affect eigenproblems and boundary conditions don't, but I don't know which are constraints and which are boundary conditions.
Thank you in advanced.
Hi Henrik,
Henrik Sönnerlind
COMSOL Employee
2 years ago
10 mag 2022, 02:17 GMT-4
To sort out the terminology here:
The two most common types of boundary conditions for PDE:s are Dirichlet conditions (I think this is what you call "constraint") and Neumann conditions (what I think you call "boundary condition").
Dirichlet conditions prescribe the variable itself, and Neumann conditions its gradient (or rather, the flux).
In pressure acoustics, the Dirichlet condition prescribes the pressure (as this is the dependent variable in the equation). This is, for example, the Sound Soft boundary condition.
The Neumann condition is a prescribed acceleration normal to the boundary (that is, the gradient of the pressure, divided by the density). This is, for example, the Sound Hard boundary condition.
Dirichlet conditions affect the eigenproblem, Neumann conditions do not. There is also a third common type of boundary condition: the Robin condition. In acoustics, it is an impedance. A Robin conditition also affects the eigenproblem.
At the beginning of this blog post https://www.comsol.com/blogs/how-to-make-boundary-conditions-conditional-in-your-simulation, you can find other examples of these types of boundary conditions.
Henrik Sönnerlind
COMSOL
The two most common types of boundary conditions for PDE:s are *Dirichlet conditions* (I think this is what you call "constraint") and *Neumann conditions* (what I think you call "boundary condition").
In pressure acoustics, the Dirichlet condition prescribes the pressure (as this is the dependent variable in the equation). This is, for example, the *Sound Soft* boundary condition.
The Neumann condition is a prescribed acceleration normal to the boundary (that is, the gradient of the pressure, divided by the density). This is, for example, the *Sound Hard* boundary condition.
At the beginning of this blog post , you can find other examples of these types of boundary conditions.
2 years ago
19 mag 2022, 23:26 GMT-4
Thank you very much!!
This is helpful.
This is helpful.
