Gaussian Laser beam
I have to define Gaussian laser pulse and I do not know how to do it here in comsol. I tried using the build in gaussian function but could not understand it. it will be very nice if someone can give some idea about it.
Thanks in advance.
MKSharma
3 Replies Last Post 9 ott 2014, 03:54 GMT-4
Posted: 1 decade ago 9 ago 2012, 09:16 GMT-4
check the Forum (search) there are a few examples using the "Definitions" Gaussian function for lines boundaries, or two gaussian functions for surface boundaries
Hi check the Forum (search) there are a few examples using the "Definitions" Gaussian function for lines boundaries, or two gaussian functions for surface boundaries -- Good luck Ivar
Posted: 1 decade ago 9 ago 2012, 10:00 GMT-4
Thank you very much for your reply Ivar.
I looked at the discussion forum but could not find anything helpful.
I am using a pulsed laser as a heat source. The shape of the laser pulse is gaussian. I am confused about which parameters shall I use to implement this in Comsol. the given gaussian function has only place like position and standard deviation. What if I need to plot laser intensity Vs time or space.
Thanks again for your help.
MKSharma
Thank you very much for your reply Ivar. I looked at the discussion forum but could not find anything helpful. I am using a pulsed laser as a heat source. The shape of the laser pulse is gaussian. I am confused about which parameters shall I use to implement this in Comsol. the given gaussian function has only place like position and standard deviation. What if I need to plot laser intensity Vs time or space. Thanks again for your help. -- MKSharma
Posted: 10 years ago 9 ott 2014, 03:54 GMT-4
Hello ,
I have the same question,have you done?Can you give me the model?
thanks!
Hello , I have the same question,have you done?Can you give me the model? thanks!
