Electric potential difference on both sides of a circle edge
I need to calculate the difference between the electric potentials on both sides of a circle edge. I tried using an Edge 2D and then generating a line graph in a 1D plot group, but that way I could only calculate the potential on the edge itself and that is not what I need. Does anyone know how I can do it?
Thanks in advance.
2 Replies Last Post 10 ago 2012, 18:52 GMT-4
Posted: 1 decade ago 10 ago 2012, 03:07 GMT-4
the solved variables are fields f(x,y,z,t, ...) so if you want to make a difference between the value of a variable for two spatial coordinates you must define a way to project the value of the other coordinate onto the location where you want evaluate your difference.
Check the "Definitions - Model coupling - projection (possible extrusion too)" and learn how to use these (check the doc and search the Forum)
Hi the solved variables are fields f(x,y,z,t, ...) so if you want to make a difference between the value of a variable for two spatial coordinates you must define a way to project the value of the other coordinate onto the location where you want evaluate your difference. Check the "Definitions - Model coupling - projection (possible extrusion too)" and learn how to use these (check the doc and search the Forum) -- Good luck Ivar
Posted: 1 decade ago 10 ago 2012, 18:52 GMT-4
Thank you very much for your advice, I really appreciate it.
