Plastic bending - is this too much to ask out of COMSOL
Hi, I'm stepping into a completely new area of physics and not sure if COMSOL has the capability. Actually, I'm not even sure if this problem is tractable numerically.
Specifically, I want to bend a metal tube across rollers to bend it get it to make a spring. I can worry about axial movement of the rollers later, so just a "simple" problem. Force a rod around some rollers so as to make a permanent deformation.
What are the parameters of the metal that would drive this, e.g. to compute how much "spring-back" is there as the rod comes out from the forming device. Etc.
Any thoughts?
Regards, John
1 Reply Last Post 11 ago 2012, 03:05 GMT-4
Posted: 1 decade ago 11 ago 2012, 03:05 GMT-4
I believe COMSOL has the capability, but it might not be already fully implemented in your way, anyhow, I would expect that you can find most of what you need in the new non-linear structural module, but I havent had time to correctly explore this one yet (from 4.3) so I cannot comment more
Hi I believe COMSOL has the capability, but it might not be already fully implemented in your way, anyhow, I would expect that you can find most of what you need in the new non-linear structural module, but I havent had time to correctly explore this one yet (from 4.3) so I cannot comment more -- Good luck Ivar
