Jeff Hiller
COMSOL Employee
2 years ago
10 giu 2022, 15:16 GMT-4
Updated:
2 years ago
10 giu 2022, 15:19 GMT-4
Hello Sebastian,
1/ It's odd that the pdf does not open properly for you within the GUI, but you can still access the pdf documentation as it is found in the COMSOL installation folder. Look for a path similar to this:
C:\Program Files\COMSOL\COMSOL60\Multiphysics\doc\pdf
2/ From what I read between the lines of your email, you need to compute the model again, not just update the solution. Update Solution is used in those cases where you added information into the model that does not affect the variables that are solved for by the model but affects postprocessing. If you add information that affects the variables that are solved for, then you need to Compute.
Jeff Hiller
Hello Sebastian,
Acculution ApS
Certified Consultant
2 years ago
11 giu 2022, 04:11 GMT-4
As Jeff says, if the parameters affect for example the geometry, you will have to compute again. For other types of parameters (like a scaling or whatever), you can typically update. For those types of parameters, it might be better in general to use an Auxilliary Sweep.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
