Reaction rate in chemical equilibrium reactions
Hello everyone. I am working on transport of diluted species in porous media (tds). I have 4 equilibrium reactions with specified equilibrium constant values (Keq).
In the formula of diluted species (d(εci)/dt+ ∇ ⋅ Ji + u ⋅ ∇ci = Ri), the chemical reactions are introduced as source terms in the form of Ri (reaction rate expression [mol/m^3-s]).
I do not understand how COMSOL calculates this Ri term. By looking at its unit it seems like rate of change of concentration of a specie (dc/dt). But this is not true because there is a difference between the Ri and dc/dt values.
Can someone explain the process of Ri calculation in COMSOL?
Thanks in advance. HK
3 Replies Last Post 15 set 2022, 02:25 GMT-4
Posted: 2 years ago 1 ago 2022, 06:33 GMT-4
When you define the chemical reaction, you must give the rate constants in a proper dimension so that Ri's becomes mol/(m^3·s). If they are no properly defined the reaction term appears in yellow color.
Lasse
When you define the chemical reaction, you must give the rate constants in a proper dimension so that Ri's becomes mol/(m^3·s). If they are no properly defined the reaction term appears in yellow color. Lasse
Posted: 2 years ago 14 set 2022, 04:40 GMT-4
Thank you for your response dear Lasse.
I have defind it well. In the equilibrium reaction node I define the equilibrium constant i.e., Keq which has no units. My question is how COMSOL calculates the Ri term from Keq?
Thank you for your response dear Lasse. I have defind it well. In the equilibrium reaction node I define the equilibrium constant i.e., Keq which has no units. My question is how COMSOL calculates the Ri term from Keq?
Posted: 2 years ago 15 set 2022, 02:25 GMT-4
I have never suceeded in using an equilibrium reaction, it just does not converge. Instead, I define an arbitrarily high forward rate constant and calculate the backward rate constant with the equilibrium constant. For example like this:
Reaction: A --> B
Ri = kf[A] - kb[B]
Keq = kf/kb ==> kb = kf/Keq.
Because the reaction rate constants are high, the reaction appears an an equilibrium reaction. You may check it by calculating [B]/[A] if it equals to Keq.
I have never suceeded in using an equilibrium reaction, it just does not converge. Instead, I define an arbitrarily high forward rate constant and calculate the backward rate constant with the equilibrium constant. For example like this: Reaction: A --> B Ri = kf*[A] - kb*[B] Keq = kf/kb ==> kb = kf/Keq. Because the reaction rate constants are high, the reaction appears an an equilibrium reaction. You may check it by calculating [B]/[A] if it equals to Keq.
