Combining particle tracing and rotating machinery modules
HOw do I combine the particle tracing and rotating machinery modules so that they can run simultaneously in a study? I am attempting to study the particle trajectories in a 3-D mixer (the same mixer design that is used in COMSOL's "Baffled Mixer" model).
When I run a study using both the rotating machinery and particle tracing modules, I will get a message that says Failed to find consistent initial values.
Last time step is not converged..
I never get convergence when I run the teo modules at the same time, but I get convergence no problem if I run either of the modules by itself. Is there a setting I would have to change?
2 Replies Last Post 30 apr 2014, 13:32 GMT-4
Hello Scott Hug
Posted: 1 decade ago 17 mag 2013, 14:55 GMT-4
I am also trying to model particles in a mechanical mixer. I first solved for the velocity field and then ran the Particle Tracing Module. It worked ok for the first time steps, but the particles seemed to freeze once they reached the impeller blades. These boundaries have a bounce boundary condition, so the particles should not freeze. Any tips anyone? Has anyone managed to successfully model particles in a stirring tank?
Thank you.
Hi I am also trying to model particles in a mechanical mixer. I first solved for the velocity field and then ran the Particle Tracing Module. It worked ok for the first time steps, but the particles seemed to freeze once they reached the impeller blades. These boundaries have a bounce boundary condition, so the particles should not freeze. Any tips anyone? Has anyone managed to successfully model particles in a stirring tank? Thank you.
Posted: 1 decade ago 30 apr 2014, 13:32 GMT-4
Hi, Have you found a solution?
