How to model the imaginary square domain ?
I want to take a square simulation domain with the cylinder located at its center.How to set the boundary of the square field as a dashed line?Any suggestion will be appreciated.
2 Replies Last Post 13 ott 2022, 23:33 GMT-4
Posted: 3 years ago 28 ago 2022, 11:43 GMT-4
Updated: 3 years ago 28 ago 2022, 11:44 GMT-4
I suggest you provide much more information. Let's start at the beginning: what physics problem are you trying to solve?
Posted: 3 years ago 13 ott 2022, 23:33 GMT-4
Thank you. I want to solve the problem that a metal cylinder is polarized when it is put into an electrolyte solution and an electric field is applied. I want to study the dynamic problem of the electric double layer and the induced charge around the metal cylinder. Now the model has been established, which is a transient model. But the final calculation results do not change after I apply different times, and I only get a look of the electric double layer in a stable state. I can't see the change process of the electric double layer establishment.
