1 set 2012, 09:06 GMT-4
I'm not sure how to do this, but I think perhaps you can manage to put the two simulations together as sub-projects of one project. Then the solution of one simulation as a variable in the project will be visible to the other simulation.
Looking forward to further comments from other people!
1 set 2012, 14:40 GMT-4
Assuming that I understand your question correctly...
Assuming your geometry is the same, then you can have any number of physics within a single model (e.g. Model 1) and create as many studies as you want such as study 1 to solve a stationary problem followed by study 2 to solve time dependent problem using results from study 1 and so on. So when you run study 1 activate the appropriate physics and the same when you run study 2, but when you run study 2 invoke results from study 1. As you already know this is done sequentially. Manuals explain this very well.
You can also see
www.comsol.com/community/forums/general/thread/31186/
Suresh
You can also see http://www.comsol.com/community/forums/general/thread/31186/
Suresh
