Compressible Euler equations
Posted 23 set 2022, 06:12 GMT-4 Fluid & Heat, Computational Fluid Dynamics (CFD) 0 Replies
I want to model the 1D inviscid compressible Euler equations without using the predefined physics node.
I have three PDEs: - for density rho: - for velocity u: - for temperature T:
Using the EOS, the pressure term in the velocity equation can be rewritten into
Instead of using the Compressible Euler Equations node, I have added three General Form PDE nodes. Unfortunately, COMSOL throws the "Repeated error test failures. May have reached a singularity." error. What can be the cause of this?
Hello Ruben D'Rose
