Visualization problems
Posted 10 set 2012, 19:49 GMT-4 Low-Frequency Electromagnetics, Results & Visualization Version 4.2a 0 Replies
In other attempt for to solve this problem, I remove the check in "Generate default plot" box, and them Comsol finish the simulation without problems or errors, but when I tried to plot the "particle trayectory", happens that, when Comsol attempts to load time data of "Particle" do not finish this task, at least for one day of elapse time.
The features of simulation are:
>>1 600 000 elements (magnetic field solution)
>>The elements for particle tracing should be more low, because is solved for part of entire geometry.
>>The time of simulation is for one second and steps of 1e-6 seconds (1 million of steps)
>>The size of Solution file is 8 Gb aprox. in .mph file, and the .mph file size is 4 GB aprox. (ccompressed file).
Thanks for your help.....
Hello Esteban Zamora
