How to create a homogeneous magnetic field
Posted 11 set 2012, 16:50 GMT-4 Low-Frequency Electromagnetics, Geometry, Modeling Tools & Definitions, Parameters, Variables, & Functions 4 Replies
Hello everyone,
my goal is to observe the magnetic flux density in an area with a homogeneous magnetic field , dependent on the relative permeability of the walls.
In the beginning i would like to simulate it in 2D, for this i need to create a homogeneous magnetic field outside the magnet itself.
The only solution i was able to produce is:
- a normal magnet defined by Amperes Law and Magnetization
- 2 Rectangles (with a high relative permeability) attached to each side of the magnet
With this a get ~homogeneous magnetic field between the two Rectangles.
So finaly my question: Is it posible to create a normal North and South pole of a magnet, without beeind attached to eachother (for getting my homogeneous magnetic field between them).
In the file attached is my model with the geometries, if i didn`t described it enought.
Best wishes,
Andreas Schneider
Best wishes,
Andreas Schneider
4 Replies Last Post 13 set 2012, 10:27 GMT-4
