Assigning a temperature value for a point in the model
The below post is related to an archived discussion
[start here]I want to give a single temperature value to the centre of the circle of the simulation that I am doing right now. But I can not give the temperature value. Can someone please help me? thank you
1 Reply Last Post 1 nov 2022, 12:00 GMT-4
Magnus Ringh COMSOL Employee
Posted: 2 years ago 1 nov 2022, 12:00 GMT-4
Updated: 2 years ago 2 nov 2022, 05:42 GMT-4
Hi Sahitha,
It is possible to assign a temperature to a point, but it is not recommended because you introduce a singularity in the model.
Right-click the Heat Transfer in Solids node (for example), and choose Pointwise Constraint from the Points submenu. Assign it to a point in the geometry (which you can create by adding a Point geometry object), and then add a constraint expression such as T-293[K] to set the temperature in that point to 293 K.
Magnus
Hi Sahitha, It is possible to assign a temperature to a point, but it is not recommended because you introduce a singularity in the model. Right-click the **Heat Transfer in Solids** node (for example), and choose **Pointwise Constraint** from the **Points** submenu. Assign it to a point in the geometry (which you can create by adding a **Point** geometry object), and then add a constraint expression such as `T-293[K]` to set the temperature in that point to 293 K. Best regards, Magnus
