Unable to Export Entirety Of Log.
Hello Everyone, I am attempting to collect all of the time steps taken by COMSOL for my transient model. After completing the simulation, the log does not include all of the steps (in this case, it only displays steps 128-175). Is there a way to expand the number of steps seen in the log after simulation? When I tried to export the log under reports , it still cuts off at 128. My current solution is to copy and paste as the log is running. Thanks for any help!
2 Replies Last Post 12 nov 2022, 19:10 GMT-5
Posted: 2 years ago 10 nov 2022, 12:16 GMT-5
You can set the log window size from Preferences. Depending on which version you are running it is either under General or under User Interface.
Henrik Sönnerlind
COMSOL
You can set the log window size from *Preferences*. Depending on which version you are running it is either under *General* or under *User Interface*.
Posted: 2 years ago 12 nov 2022, 19:10 GMT-5
This worked, thank you Henrik!
>You can set the log window size from *Preferences*. Depending on which version you are running it is either under *General* or under *User Interface*. This worked, thank you Henrik!
