integer function
Hello All,
Does anyone know if it is possible to use the integer function in comsol? I have found the "round" and "ceil" and "floor" but none of them are giving me the same results as an integer function would.. I thought I would be able to use int(x) but comsol uses that for interpolation! Any ideas?
Thank you.
Kelley
1 Reply Last Post 18 set 2012, 15:56 GMT-4
Posted: 1 decade ago 18 set 2012, 15:56 GMT-4
if nothing else work, try:
my_int() = sign(x)*floor(abs(x))
and probably
my_other_int = x - mod(x,1)
should also work
But indeed I see no "int" at p 143 of the user guide (v4.3)
Hi if nothing else work, try: my_int() = sign(x)*floor(abs(x)) and probably my_other_int = x - mod(x,1) should also work But indeed I see no "int" at p 143 of the user guide (v4.3) -- Good luck Ivar
