Electromagnetic field simulation
Posted 19 set 2012, 06:05 GMT-4 Low-Frequency Electromagnetics 1 Reply
Hello! Please help me with electromagnetic field simulation. I appriciate any help! I have two wires, the first one is active, the second one is passive. I need to reserch the influence of the active wire to the passive one.
What I do:
1. Select 3D-AC/DC mode-Magnetic and Electric Fields- Stationary
2. Create two cylinders (copper) in the block (air)
3. Select Surface Current for the active wire and Perfect Magnetic Conductor for the passive wire
The difficulties:
1. I am not sure that I have selected the necessary mode
2. I need to start up the alterning current in the active wire (sin). How can I do that?
3. There is the Magnetic Insulation property in Magnetic and Electric Fields mode. Where can I use it? For what figgure?
That you very much in advance!
What I do:
The difficulties:
1 Reply Last Post 20 set 2012, 02:40 GMT-4
