25 set 2012, 10:54 GMT-4
I do not really understand your question, if you have a mapped function for your surface and you want to get a regular shape to fit to this "measured" surface, you have an optimisation problem, that can be easily solved with the optimisation module, and with some math and equation writing, for a simple case in standard COMSOL
José Mauricio Urbano Caguasango
25 set 2012, 12:34 GMT-4
Hi! Maybe i wasn't clear with my problem ;)
I am using the structural mechanics library and Livelink in Matlab. I am simulating the human cornea as an empty semisphere. The only load acting is a distributed force (pressure) from the inside. This load results in a deformation of the entire semisphere. I want to know a geometry such that, when the loads are applied, the deformed cornea coincides with a geometry that i know (Lets call it "Def_geom"). For this I am following the next procedure:
1. I start with the geometry that i know "Def_geom".
2. I apply the loads and get the displacement on each node with the command verticesOut = struct2cell(mpheval(model, {'x' 'y' 'z'}))
3. I run the simulation again, but I define a new mesh, which is my original mesh "Def_geom" -- the displacements.
4. I define the new mesh with the command model.mesh('mesh2').data.setVertex(meshCoordinates), where "meshCoordinates" correspond to the corrected mesh.
5. I iterate this condition.
I have realized that the corrected mesh changes on each iteration, which is expected, but i found that the displacement after the loads was always the same. I want to know the following:
1. Am I using the right commands to get the displacement on each node?.
2. Am I somehow defining a new mesh but Matlab is only recognizing the original mesh?
Yesterday I changed the command verticesOut = struct2cell(mpheval(model, {'x' 'y' 'z'})) with the capital X,Y,Z:
verticesOut = struct2cell(mpheval(model, {'X' 'Y' 'Z'})) and it seemed to work, but i don't know why.
I appreciate any help :D:D
José
José
26 set 2012, 01:43 GMT-4
since V4 I have given up using Matlab with COMSOl, even if I still have the the livelink active ;) I manage to stey fully in the COMSOL GUI, so far
My way would be to define an interpolation function My_Z(x,y) from your measured data where My_Z is the height and X-Y is the extent of your cornea area, provided the correct coordinate transform to map the X,Y,Z to your geometry.
Then I apply a scalar pressure P to the approariate cornea beoandary and define P as a "global equation" with the equation
"intop1((w-My_Z)^2)" = 0
where w is the Z deformation field of your cornea model (assuming Z is the natural direction of deformation, this depends on your geomerty orientation as mentioned above) and intop1() is the integration over the full Cornea area (boundary integration)
COMSOL will minimise the global equation and leave you with the P requried to fit your cornea to the measured deformation in a least square minimisation way
I hope I'm clear.
I hope I'm clear.
28 set 2012, 16:45 GMT-4
Hi Ivar! Thanks for your quick response! :D
I found your approach very interesting, i.e. defining the simulation as an optimization problem. In my case I am not trying to find the pressure field (which is constant), but the displacement field. I began working with Comsol a month ago, and I have not much experience. Could you illustrate me please how could I set up this interpolation function and the minimization problem? I would really appreciate that....
Thanks again!
José
Thanks again!
José
30 set 2012, 08:33 GMT-4
there are a few exaples in the model library, among one on a global Heat "T" control example
else you have things like
www.comsol.com/showroom/gallery/9999/
www.comsol.com/showroom/gallery/4356/
www.comsol.com/showroom/gallery/407/
http://www.comsol.com/showroom/gallery/9999/
http://www.comsol.com/showroom/gallery/4356/
http://www.comsol.com/showroom/gallery/407/
