particle tracing
Posted 26 set 2012, 13:55 GMT-4 0 Replies
I am working on a 2D, time dependent analysis of laser percussion drilling that focuses on the early stage of melt ejection. Here, we are using a non-isothermal laminar flow physics. The target material(iron) is hit by a laser beam, and during each optical pulse, the central portion of the target area heats to a liquid then vapor state.
I am trying to do the particle tracing in the target material under these conditions:
1) Within a particular depth on the target material. (i.e, 50um below the surface)
2) And applying a time range.
Can anyone let me know the procedure to do it, and on what basis should i set up the X & Y component expressions to plot the tracing.
Harini.
Hello Harini Patlolla
