How to generate random array
I have a model that I would like to use the array command to generate same structure in the model. However, array command gives equal distances between the structures but I would like to place the structures randomly in the space. Any way to do that faster than placing one by one?
Thank you in advance
2 Replies Last Post 20 feb 2023, 08:41 GMT-5
Posted: 2 years ago 20 feb 2023, 07:59 GMT-5
Updated: 2 years ago 20 feb 2023, 10:56 GMT-5
There are several possibilities.
One, very lightweight method, is shown in the attached screenshot: Use a Copy node referencing a random function.
A more sophisticated variant, using a model method, is described in this blog post:
https://www.comsol.com/blogs/how-to-create-a-randomized-geometry-using-model-methods/
An important thing to consider, is whether it is a problem or not if the generated objects overlap.
Henrik Sönnerlind
COMSOL
There are several possibilities. One, very lightweight method, is shown in the attached screenshot: Use a *Copy* node referencing a random function. A more sophisticated variant, using a model method, is described in this blog post: An important thing to consider, is whether it is a problem or not if the generated objects overlap.
Posted: 2 years ago 20 feb 2023, 08:41 GMT-5
thank you!
>There are several possibilities. > >One, very lightweight method, is shown in the attached screenshot: Use a *Copy* node referencing a random function. > >A more sophisticated variant, using a model method, is described in this blog post: > > > >An important thing to consider, is whether it is a problem or not if the generated objects overlap. thank you!
