The current application problem
I want to simulate the current distribution in the conductor. How can I apply the current vertical to the surface of the conductor and simulate the magnetic field distribution around the air domain nearby?
1 Reply Last Post 15 mar 2023, 05:10 GMT-4
Andreas Bick COMSOL Employee
Posted: 2 years ago 15 mar 2023, 05:10 GMT-4
Dear Cris,
You can simulate the current distribution in the conductor and the magnetic field around the air domain using COMSOL Multiphysics and, most likely, the "Magnetic Fields" interface. To do so, apply the "Coil" domain condition with the "Single Conductor" option for modeling a solid conductor. To define the current direction vertically, adjust the settings in the "Input" sub-node.
You can find a comprehensive course about coil modelling here:
https://www.comsol.de/support/learning-center/article/Modeling-Electromagnetic-Coils-8251/112
Regards, Andreas
Dear Cris, You can simulate the current distribution in the conductor and the magnetic field around the air domain using COMSOL Multiphysics and, most likely, the "Magnetic Fields" interface. To do so, apply the "Coil" domain condition with the "Single Conductor" option for modeling a solid conductor. To define the current direction vertically, adjust the settings in the "Input" sub-node. You can find a comprehensive course about coil modelling here: https://www.comsol.de/support/learning-center/article/Modeling-Electromagnetic-Coils-8251/112 Regards, Andreas
