wrong number of function arguments
I keep getting the same error for my analytical function
"Wrong number of function arguments
Number of arguments expected: 3"
But as far as I can tell, I have defined 3 arguments in my function.. so I don't understand the error!
expression: a_c*pore_V(x,y,z)
Arguments: x, y, z
(a_c = a variable and pore_V(x,y,z) = random fxn)
Does anyone know whats happening?
Thank you!
Kelley
3 Replies Last Post 12 ott 2012, 13:32 GMT-4
Posted: 1 decade ago 11 ott 2012, 01:30 GMT-4
no, not like that, probably you must make a simple model example and post that too (you do not need to give the full model, "just" reproduce the error in a simple new model
Hi no, not like that, probably you must make a simple model example and post that too (you do not need to give the full model, "just" reproduce the error in a simple new model -- Good luck Ivar
Posted: 1 decade ago 12 ott 2012, 13:07 GMT-4
Here is a simplified (but very similar) model with the same error. Maybe I am misunderstanding how to define the arguments?
Posted: 1 decade ago 12 ott 2012, 13:32 GMT-4
I think I figured out the error... I was trying to use the analytic function in the model in an anisotropic flow field. I was defining the flow field like
f(x) f(y) f(z)
but I think I needed to do
f(x,x,x) f(y,y,y) f(z,z,z)
for there to be 3 arguments in the model. Does that sound correct?
or should it be defined
f(x,y,z) for each flow direction (xx, yy, zz)?
I think I figured out the error... I was trying to use the analytic function in the model in an anisotropic flow field. I was defining the flow field like f(x) f(y) f(z) but I think I needed to do f(x,x,x) f(y,y,y) f(z,z,z) for there to be 3 arguments in the model. Does that sound correct? or should it be defined f(x,y,z) for each flow direction (xx, yy, zz)?
