16 ott 2012, 07:39 GMT-4
I was struggling with as well with acoustics, but I concluded that if you do a frequency domain study COMSOL assumes that loads on your system are in a sinusoidal frequency.
16 ott 2012, 10:32 GMT-4
the external loads / forces you apply are ALL considered as amplitudes (might be complex) of the frequency span, and the frequency is defined in the solver node, as a value or a range
This is the default way for harmonic developments, check the equation tab of the main physics nodes
20 ott 2012, 08:44 GMT-4
Hi Ivar,
thanks for your help. I checked the equations of the frequency domain and, from what I understand, the frequency study considers as periodic only Fv ( a body load) while I'd like to simulate a periodic boundary load. In fact, I'm trying to simulate the effect of an indentation test on the poroelastic material. Can you please tell me how to reach this goal?
Greta
Hi Ivar,
Greta
20 ott 2012, 14:46 GMT-4
Normally all loads are "harmonic", not only body loads, also boundary loads. Check carefully, and i.e. make a simple example to get convinced
