Problems in Calculating Heat Flow Using COMSOL
Posted 11 mag 2023, 10:28 CEST Fluid & Heat, Heat Transfer Version 6.0 0 Replies
I used COMSOL to build an empty box model (the middle part is air), and there is a heat source with a constant temperature in the center of the box. I want to know the amount of heat that the box system conducts to the outside. I calculated the heat flux on the surface of the box, but I don't know how to use this data. Hope someone can give me some help, thanks.
Hello yun Lu
