How to Draw a Bowtie antenna in Comsol 4.3a
Dear all,
I want to know how to draw a bowtie antenna in comsol 4.0 or above. I tried to draw a polygon and then extrude it, But it do'nt work. In other words, I want to draw a triangluar prism in comsol.
I know that it is possible to draw a bowtie by intersecting two rotated rectangular boxes, But I want to know if there is any simpler way to do so.
Thank you all,
Abramo
4 Replies Last Post 21 ott 2012, 06:17 GMT-4
Posted: 1 decade ago 20 ott 2012, 14:47 GMT-4
the COMSOl geometric palette lets you draw a polyline easil, by handy, you can then edit the coordinates to make them better suit your need
Hi the COMSOl geometric palette lets you draw a polyline easil, by handy, you can then edit the coordinates to make them better suit your need -- Good luck Ivar
Posted: 1 decade ago 21 ott 2012, 04:04 GMT-4
dear Ivar,
Thank you for the quick reply, but I don't want to draw a triangle but a triangular prism. With polygon it is possible to draw a triangle.
Thanks again
Abramo
dear Ivar, Hi Thank you for the quick reply, but I don't want to draw a triangle but a triangular prism. With polygon it is possible to draw a triangle. Thanks again Abramo [QUOTE] Hi the COMSOl geometric palette lets you draw a polyline easil, by handy, you can then edit the coordinates to make them better suit your need -- Good luck Ivar [/QUOTE]
Posted: 1 decade ago 21 ott 2012, 04:28 GMT-4
still I do not catch what you are missing ;) extrusion of a closed polygone (wors case combine it) is possible but ok paralle to the surface, if you need to cut it oblique, you need to create a 2nd workplane, perpendicular and make a secont extruded prism and take the difference, still rather easily done ...
Hi still I do not catch what you are missing ;) extrusion of a closed polygone (wors case combine it) is possible but ok paralle to the surface, if you need to cut it oblique, you need to create a 2nd workplane, perpendicular and make a secont extruded prism and take the difference, still rather easily done ... -- Good luck Ivar
Posted: 1 decade ago 21 ott 2012, 06:17 GMT-4
dear Ivar,
now I got it, Thank you!
Good luck!
Abramo
dear Ivar, now I got it, Thank you! Good luck! Abramo [QUOTE] Hi still I do not catch what you are missing ;) extrusion of a closed polygone (wors case combine it) is possible but ok paralle to the surface, if you need to cut it oblique, you need to create a 2nd workplane, perpendicular and make a secont extruded prism and take the difference, still rather easily done ... -- Good luck Ivar [/QUOTE]
