Andrea Ferrario
COMSOL Employee
25 ott 2012, 09:07 GMT-4
Hi Nicola,
1) the value you enter in Vsrc is the amplitude. It is multiplied by a phase factor given computed from the value you write in the Phase textbox. It is also possible to write a complex value in Vsrc. The actual frequency-domain voltage source (phasor) is computed as Vsrc*exp(i*phase), so if you want to specify a complex phasor directly you can simply write it in Vsrc and leave phase = 0.
2) The External I vs U and U vs I features act, respectively, as a current-controlled voltage source, and as a voltage-controlled current source. So if your circuit is made by a voltage source and a I vs U only, you are effectively connecting two voltage sources in parallel and this can cause an inconsistency. The solution can be to add a small series resistance, as you did, or use the dual entity (U vs I), if the connected object supports it (e.g. Coil features in the AC/DC module can be connected to both entities).
Andrea Ferrario
Electromagnetics Group
COMSOL AB
Hi Nicola,
Andrea Ferrario
COMSOL AB
25 ott 2012, 09:15 GMT-4
Hi Andrea,
and thanks for your answears.
Vsrc amplitude means that i have to multiply for sqt(2) in order to reach an effetive values? I mean 3000V in DC of Vrc are 3000*sqrt(2) in AC right (in order to have compatible power losses)?
Nicola
Hi Andrea,
Nicola
Andrea Ferrario
COMSOL Employee
25 ott 2012, 09:21 GMT-4
Yes, correct.
Andrea Ferrario
COMSOL AB
Yes, correct.
Andrea Ferrario
COMSOL AB
25 ott 2012, 09:23 GMT-4
perhaps you still need to have both physics self constained, and a CIR physics with only a source and no sink (resistance) is probably then not accepted.
I would have to try (I did and it seems that my comment above stands, but adding a 1MOhm resistance is not going to change much), never though of that, But also, a simple AC source you can write it out within the other physics without the extra CIR part.
Normally the V source in most physics is the amplitude, no the rms, but that needs to be rechecked for the CIR, might be different
Well other werre quicker than me here that's good ;)
