Two-Step Study Issue
Hi all, I'm having an issue implementing something interesting that I think COMSOL should be able to do.
I have a step which solves for the steady state temperature distribution in a 2D domain subjected to temperature boundary conditions. After the simulation executes, I evaluate the heat flux across one of the boundaries, which happens to be a non-constant distribution.
In a second step, I want to prescribe this heat flux distribution as a boundary condition at that same boundary, swap some of the other BCs, and solve for the new temperature distribution in the domain.
It's really easy to set up a two-step study and use the "Modify for Step" option to assign BCs that are only active in step 1 vs step 2. But the part I am struggling with is assigning this flux boundary condintion is a solution from the previous step. I have tried a few things, including making a second study instead of a second step, trying to reference the results using "sol1.ntflux," bringing in two instances of heat transfer physics, but nothing has worked.
Any tips? Thanks!
3 Replies Last Post 8 giu 2023, 13:05 GMT-4
Posted: 2 years ago 4 giu 2023, 19:11 GMT-4
Updated: 2 years ago 4 giu 2023, 19:14 GMT-4
I'm guessing that the "two instances of heat transfer physics" approach is your best bet, but the devil is in the details. As you seem to already know, you need to carefully set the active/inactive physics as the problem solving progresses from one stage to the next and you also need to ensure the values of certain computed variables get transferred to the next stage. Anyway, I encourage you to post your .mph file to the forum so that it can be reviewed by many others here, and so that the issue(s) in your particular model will be easier to identify.
Posted: 2 years ago 5 giu 2023, 04:07 GMT-4
Looks like it should be possible to use the withsol() operator to pick up the flux from the first study step.
Henrik Sönnerlind
COMSOL
Posted: 2 years ago 8 giu 2023, 13:05 GMT-4
Updated: 2 years ago 8 giu 2023, 13:05 GMT-4
Thank you both, this was exactly the pointer I needed. I found helpful examples in this article: https://www.comsol.com/support/learning-center/article/Examples-of-the-withsol-Operator-59801#:~:text=For%20example%3A,from%20the%20nearest%20stored%20timesteps..
Lawrence Smith
Thank you both, this was exactly the pointer I needed. I found helpful examples in this article: [https://www.comsol.com/support/learning-center/article/Examples-of-the-withsol-Operator-59801#:~:text=For%20example%3A,from%20the%20nearest%20stored%20timesteps.](http://). Best, Lawrence Smith
