How to reduce the model file size
I built a 3D heat transfer, time dependent model. After simulation, the model file goes beyond 5G. Is there anyway I can reduce the file size? I only care how the maximum temperature changes with time. The detailed temperature information in the 3D structure is useless to me.
Thank you very much.
3 Replies Last Post 6 apr 2016, 02:03 GMT-4
Posted: 1 decade ago 14 nov 2012, 08:15 GMT-5
After simulation, you can "clear solutions" before saving your file by right click on "Solver Configurations" of "Study"
Dinh
Hi, After simulation, you can "clear solutions" before saving your file by right click on "Solver Configurations" of "Study" --- Dinh
Posted: 1 decade ago 14 nov 2012, 09:22 GMT-5
... but make sure you document the results of interest before clearing the solutions, because you loose ALL results this way and you will need to solve again to perform any postprocessing later.
Cheers
Edgar
... but make sure you document the results of interest before clearing the solutions, because you loose ALL results this way and you will need to solve again to perform any postprocessing later. Cheers Edgar
Posted: 8 years ago 6 apr 2016, 02:03 GMT-4
Tr with 7zip......
net-informations.com/q/mis/7zip.html
Mark
Tr with 7zip...... http://net-informations.com/q/mis/7zip.html Mark
