Estimating memory requirements, constraining memory usage
Posted 28 giu 2023, 08:56 GMT-4 Studies & Solvers, Modeling Workflow Version 6.1 1 Reply
I'm a new user to comsol trying to port my old abaqus models to comsol.
Trying to run my first model I run into the problem that all RAM memory gets consumed by the solver and then the system simply kills the program (at'least this is what thinks is happening as the output messages indicates that the program is killed). I'm a bit surprised as I have 128 GB RAM and the model consists of no more than 1138260 elements (quadratic serenipity) and it seems that comsol make use of 8 of the available 16 cores on my machine.
In abaqus I can get an estimate of the minimum RAM required to run a model as well as the RAM required to optimally run the model so I wonder if there are some similar functionality in comsol?
Similarly in abaqus I can configure the maximum ammount of RAM the software may use, is this possible in comsol?
If of importance I'm on a linux system trying to run the model in batch mode. The model uses the solid mechanics interface, a viscoleastic material, include spring foundations and is a time dependent study. The mesh is a mixture of quadrilaterals and tetrahedrals.
