Drawing A Spiral in 3D
hi!!
how can i draw a spiral in 3D in COMSOL 3.5a ?
5 Replies Last Post 27 feb 2013, 11:54 GMT-5
Posted: 1 decade ago 9 nov 2012, 08:11 GMT-5
There are no tools to draw a spiral in version 3.5a. You can do it in the current version of the software, version 4.3a though.
Posted: 1 decade ago 26 feb 2013, 12:10 GMT-5
how to draw a rectangular spiral in 3D in comsol 4.3a
Posted: 1 decade ago 27 feb 2013, 03:30 GMT-5
in 3.5 I do not believe its possible (cannot remember for sure ;) But in 4.3 you draw a workplane, the square (or better filleted square profile (if in ACDC to avoid singularities on the edges) then add a Helix with minor radius of "0" to get the spiral shape (adjust position accordingly to start in the middle of your square profile, then you use the sweep,
What I have always problems with then is the twist angle right ;)
Hi in 3.5 I do not believe its possible (cannot remember for sure ;) But in 4.3 you draw a workplane, the square (or better filleted square profile (if in ACDC to avoid singularities on the edges) then add a Helix with minor radius of "0" to get the spiral shape (adjust position accordingly to start in the middle of your square profile, then you use the sweep, What I have always problems with then is the twist angle right ;) -- Good luck Ivar
Posted: 1 decade ago 27 feb 2013, 08:29 GMT-5
Thanks for reply,I will try it
Posted: 1 decade ago 27 feb 2013, 11:54 GMT-5
There IS an option to draw a spiral in 3.5a!
However, the catch is that this needs to be done in "comsol script" or matlab environment...
I think the command in comsol script is something like "helix3d" or something...
After drawing it in script, you can import the geometry back into comsol
Sorry I can't give more details because I haven't used 3.5a in years, but I know that back when I did use it I was able to successfully draw a helical coil for analysis!
--matt
There IS an option to draw a spiral in 3.5a! However, the catch is that this needs to be done in "comsol script" or matlab environment... I think the command in comsol script is something like "helix3d" or something... After drawing it in script, you can import the geometry back into comsol Sorry I can't give more details because I haven't used 3.5a in years, but I know that back when I did use it I was able to successfully draw a helical coil for analysis! --matt
