force-assisted two-way shape memory effect in NiTi alloy
Hello, I am trying to simulate the force-assisted two-way shape memory effect in NiTi alloy. However, when setting the temperature change, the minimum temperature can only be higher than the martensitic phase transition start temperature. This temperature setting leads to incomplete martensitic phase transformation. What can I do to solve this problem? Thank you very much for your help.
0 Replies Last Post 14 ago 2023, 22:54 GMT-4
Hello lu Chen
